Some of these are known bugs, e.g. the auto-highbeam. Others I have never heard about, like the indicator (?) fault. So in my humble opinion, yes, you should talk to your dealer about this. Especially the last item.
Because of missing reliability I don’t use those automatic stuff most of the time. This could be fixed/upgraded with OTA updates. But I wouldn’t bet on it.
For the locking issue: do you have set/tested different distances to open/lock in the app?
He means blind spot indicator in right mirror.
This is/was an issue here also.
Don’t remember if it was solved actually. Only on FL models.
There’s another problem I don’t know if it’s a problem.
With the xpedal activated. While the car is stopped and in an area where there is no noise for example in a garage. I squeeze the accelerator and release. It makes like a sound. If it’s not there, the xpedal doesn’t make that sound.
If WHAT is “not there”? I’m sorry, but maybe you should try translate.google.com, describe the problem in your native language and copy the english translation. Otherwise, your descriptions are kind of hard to understand.
Just an idea: when you have come to a complete stop and the car doesn’t move on it’s own when you let go of the brake pedals, autohold (= the parking brake) should be engaged. Otherwise, the car would slowly start to crawl forwards. So if autohold is engaged and you press the accelerator, the parking brake has to disengage, and this could make an audible noise.
Maybe I have this sound also. If driving slowly on a parking lot towards a street and have to stop at about 3 to 6 km/h I can hear a „clonk“ in the front right area of the car.
Don’t know what it is. Could be the brake pads that are pushed onto brake disk.
I’m not worried about that.
